Blanker
Apr 04, 2017Aspirant
EDA500 Expansion chasis + RN312= combine volumes for XRAID2?
Hi everyone, I just got the 31200 (2-bay) and the EDA500 (5-bay) expansion chasis. I was hoping to add 7 disks and set up an XRAID2 volume. I just read some fine print that the eda500 will create a...
Blanker
hi, thanks for the response, though it seems to be contradictory of this guys post:
https://community.netgear.com/t5/New-to-ReadyNAS/Netgear-EDA500/td-p/887978
is Kossboss wrong?
The way I am looking at it, a raid6 will provide better protection across all 7 disks. Especially in the case of a drive failure, and then an URE while the array is rebuilding.
Apr 04, 2017Guru - Experienced User
Blanker wrote:
is Kossboss wrong?
I believe he was. With xraid, there should a second volume for the eda-500 called eda1. I'm not sure if you can set up a flexraid volume that spans the two chassis or not.
I agree.
Though if the cable disconnects with the systems running, the results might be unpredictable if you were to configure single volume. If power drops on the EDA but not on the RN312 you might run into trouble.
- BlankerApr 04, 2017Aspirant
I am fooling around with it as we speak. It appears that with flexraid I can create a 7-disk volume that spans both chasis. I just need to confirm that there is ZERO way to do this with xraid.
- StephenBApr 04, 2017Guru - Experienced User
XRAID is automatic, so I don't see how you could set it up with XRAID enabled. You might be able to re-enable XRAID after the volume is created.
- mdgm-ntgrApr 04, 2017NETGEAR Employee Retired
Having a single volume spanning the main chassis and the EDA is strongly discouraged for reasons already mentioned.
If you want a 7 disk volume you'd be much better off both for performance and reliability by getting an 8-bay ReadyNAS.
