cgthayer
Jun 12, 2021Follower
EERO and ReadyNAS
I have two ReadyNAS (a 2TB and 4TB). I recently moved to use an "eero pro" for mesh wifi. Both devices are not showing up on my network although they're wired (over ethernet) to the eero. The DHCP...
Sandshark
Jun 12, 2021Sensei
I'm not familiar with RAIDar on Linux, but this doesn't seem quite right:
IP=192.168.4.30 Mac=4c:34:88:54:26:b2 BroadAddress=192.168.7.255
The listed addresses are in different subnets. Did you previously have your LAN subnet as 192.168.7.xxx, and might you have assigned the NAS a static IP in that range?
Jun 13, 2021Guru - Experienced User
Also, did you try browsing to http://192.168.4.30/admin instead of using curl?
