JVand
Nov 11, 2020Star
Error - Trust anchor for certification path not found
I regularly remotely download files from my NAS to either my phone or tablet using the Android ReadyCloud app. Recently I have been unable to do so due to an error - "Trust anchor for certification ...
- Nov 18, 2020
The certificate issue should be resolved on the server side, please check your Android app, it should be working now.
Thank you all.
Parish31
Nov 13, 2020Initiate
I have the same issue and wonder whether it is linked to a software update on my android a few days ago- all attempts to download files since the have failed with the same 'trust ancertificate cate' error message.
Sengineer
Nov 14, 2020Tutor
It's only sources where the CA certificate requires to be from a trusted source or has expired. We had this at work, once I found the actual issue was solved in fifteen minutes by requesting an updated certificate and applying.
Netgear will need to do the same thing with their APP and pubish the update in the App store.
If you're seeing it from website downloads then they will need to update their CA and or site certificate.
- bjmigrinoNov 14, 2020Initiate
how to resolve this issue?
