agmunari
May 08, 2022Guide
Error Knem
Hello, I was usually backing up to an external USB drive as usual. But after a few hours from the beginning the message knem_chache_alloc + 9B appears, and the backup does not finish. I have to resta...
agmunari
May 09, 2022Guide
thanks for the help, the nas is a Readynas 516 with 6 x 4tb disks in RAID 10
May 10, 2022Guru - Experienced User
Thanks.
I suggest first downloading the full log zip file, and see if you can find any disk-related or BTRFS related errors at around the time the NAS crashed. You can look in system.log, kernel.log, and systemd-journal.log. Looking at the backup log might also be helpful.
I'd also make sure that the volume is still mounted normally - if the NAS finds issues with the file system, it can remount the volume as read-only to help protect the data. If the volume is still mounted normally, and if you haven't tried simply rebooting the NAS and running the backup again, then I suggest trying that.
Also, check for any warnings that the root (OS partition) is filling.
FWIW, although we should reclaim the space freed up by your file deletions, I think completing the backup is the first priority. If you have between 20-30% free space, then you do have enough. On my own NAS, I plan for expansion when the free space drops to about 20% (making sure the systems always have at least 15% free space).
