papaj0hn
Dec 07, 2021Aspirant
error when connecting a USB device
When I plug in a 5TB Seagate storage device I get the following error. "external storage device is connected but the file system is not recognized". My NAS has recognized other USB devices, some w...
- Dec 17, 2021
Is that drive USB powered? If so, that's a pretty big drive to expect a NAS to power on its own (though USB3 is suposed to be rated at high enough current for most). If the electronics is powering up but the drive isn't spinning up, that could cause it.
NOTE: If a drive comes with one of those cables that lets you plug into two USB ports to get enough current, it's not usually going to work on a ReadyNAS.
Laserbait
Dec 17, 2021Luminary
Can you format the disk as EXT3 or 4 from the NAS when plugged into the USB3 port?
ETA: What is the exact model number of this drive?
Sandshark
Dec 17, 2021Sensei
- papaj0hnDec 18, 2021Aspirant
I too think it's a power issue. Although the device, cable and NAS are USB 3.0 the NAS may not offer enough power. But the NAS does know that a device is plugged in yet It is not recognized, so I really don't know. I've moved on and did my Robocopy of data to backup . Thanks to all who tried to help.
