lukek
Dec 08, 2013Initiate
exFAT Support on ReadyNAS 102
Trying to find out if there is exFAT support for an external usb hard drive on a ReadyNAS RN102 - I cannot find this information. Anyone know? Cheers, Luke
xeltros
Dec 09, 2013Apprentice
Since the readynas is based on debian, you can add support for exfat via apt-get.
I believe exfat-fuse and exfat-utils should do the trick. Then try to plug your device, wait a minute to see if it auto mounts, otherwise mount it manually.
Don't know how netgear handle the SSH for the warranty though.
