lukek
Dec 08, 2013Initiate
exFAT Support on ReadyNAS 102
Trying to find out if there is exFAT support for an external usb hard drive on a ReadyNAS RN102 - I cannot find this information. Anyone know? Cheers, Luke
Dec 09, 2013Guru - Experienced User
Oops - you are correct. I've had it enabled since the original closed (pre-launch beta), and probably forgot about the click through warning.
My understanding is that they aren't supposed to deny support unless there is some evidence that your actions broke the system.
