BtrieveBill
May 03, 2024Aspirant
Failed Drive Replaced, Recync Complete, But Volume Is Still Degraded
My RN312 has been working fine for many years. Just recently, one of the 4TB WD Black drives indicated a failure. I removed the failed drive and replaced it with a newer 4TB WD Black drive with the...
- May 07, 2024
BtrieveBill wrote:
I hesitate to do that because I'm not sure where the RN312 keeps its brain.
Everything is on the disks - config files are stored in the OS partition, any apps are installed to a hidden folder on the data volume.
BtrieveBill wrote:
The SMART data shows that the last failure on that drive was in 2022, but that it is showing 53 pending sectors
Personally I would have replaced that disk. Generally I consider replacement when the bad sectors move into the 20s.
BtrieveBill wrote:
I copied all of the data off of the volume to my new Synology NAS, so I have no fear of losing anything.
Good.
One option is to save the config files, do a clean install on new disks, and then restore the config. Personally I'd use Seagate Ironwolf or WD Red Plus. If you use desktop class drives, make sure they are not SMR. Most desktop drives in the 2-6 TB range are now SMR.
A second option is to try cloning the disk to a replacement drive. Then power up the NAS with that drive installed. Delete all the files and snapshots, and restore the files from the Synology. After that hot-insert a second drive (ideally new) and wait for it to sync. That would preserve your configuration and the OS partition (assuming they are not damaged).
Sandshark
May 03, 2024Sensei
Sounds like your new drive is bad. Best thing to do it attach it to a PC (via SATA or a USB to SATA adapter) and test it with vendor tools.
If it tests good, then test the old one, too. If it also tests good, the problem is in the NAS.
