connor25's avatar
Sep 24, 2015
Few questions
I have a few questions, as am pretty new to NAS102   - Does it come with free backup Cloud space or is this a cost? - I currently have just 1 x drive, if I up this to 2 x and use Raid am I right i...
  • StephenB's avatar
    Sep 24, 2015
    connor25 wrote:
    - Does it come with free backup Cloud space...?
    No.  There are a couple of third party apps available (egynte and idrive) but they are linked to 3rd party services.
    - I currently have just 1 x drive, if I up this to 2 x and use Raid am I right in thinking everything will be duplicated so in case of a failure you can switch drives, and is this possible remotely? via Teamviewer etc?
    With RAID-1 the mirroring is invisible to the user.  There is no manual drive switching.  If a drive fails, the system just switches.
    You can (and should) set up email alerts so you get warning messages on failing drives (and other errors).
    Even with RAID you still need backups (that is true with any NAS).  It is never wise to trust your data to a single device.
ProSupport for Business
