landogarner
Sep 28, 2007Aspirant
File Manager inside Readynas
It would be nice to be able to do file manipulations directly inside ReadyNAS GUI.
We have millions of files on our ReadyNAS that come from security cameras and it takes hours to delete them over LAN access with high LAN load during this period.
I think it would be much faster to select the files to be deleted inside the ReadyNAS GUI and then let it do the job.
Any chance for implementing this feature ?
Thanks.
Thanks.
- KarlVWAspirantNot sure if I understand the issue, I would think using FTP server, you could delete the files faster than using SMB/CIFS
Also going to a CMD/COMMAND/DOS PROMPT deleting the files would be faster than using windows exploder
:slap: :slap: Do I need to slap myself?? - ajwhAspirant+1
- +11111 on the internal file manager and if it could also set file and directory access permissions.....I send ya to Disney World.
- xtrips1AspirantHello,
All is working fine but I need something more.
I need to copy huge amounts of data from an external drive connected via USB to the NAS itself.
The problem is that through the web interface you cannot copy from the USB root to the NAS' root.
How can I do that?
The obvious reason for all that is to have the copy process run on the NAS.
Thank you - StephenBGuru - Experienced UserYou could try a frontview backup job.
