joshuativis
Jun 26, 2020Aspirant
File Transfer Problems
About a week ago i started having problems transferring any files from a windows 10 computer to my readynas drive. All are hard wired in and below is what i have done to try and correct the issue. ...
Jun 26, 2020Guru - Experienced User
You can't copy files in either direction? But you are seeing them in File Explorer?
joshuativis
Thanks for you response. Amazingly when i sat down to work on the problem tonight it started working again.
