bolter
Feb 28, 2021Aspirant
File Transfer problems
I am currently runing a Readynas ultra 6 plus with 3 6TB and 3 3TB WD Reds via windows 10 pro, the PC is running i7 intel second gen with 16g of ram. The problem i'm having is if I transfer files lar...
- Apr 11, 2021Thanks to everyone that helped. I have now upgraded to 4gb of ram and that has now helped my file transfer problems. Thank you.
Sandshark
Feb 28, 2021Sensei
How much RAM is in the NAS? Some have found that the stock 1GB of the legacy units is insufficient with OS6.10.x.
You may want to open an SSH session up the next time before you do that and have top running to see if any process(es) is/are getting to 100% of CPU usage.
Are you performing a volume balance somewhat regularly?
bolter
How much RAM is in the NAS? it is still running the stock amount 1GB
You may want to open an SSH session up the next time Will do that if I knew how?
Are you performing a volume balance somewhat regularly? I have never done that, ever.
Thanks for the advice.
