ChuckMilne
May 08, 2021Initiate
Firmware 6.10.5 web interface broken in final release
My RN10200 had a 2tb drive die - so I replaced with two 4TB Seagate Iron Wolf NAS drives. There was a notice that a new version of the firmware was available 6.10.5 so I figured I should update this....
- May 09, 2021
I was eventually able to get Firefox on my laptop to get on the the NAS web interface after doing a lot of playing around clearing caches/histories, etc. So I chose the firmware update feature in the interface to go back to the 6.10.3 version. After a reboot this seem to allow access to the NAS interface from everywhere again. So I'm not sure what the advantages might be of 6.10.5 - but the problems with the web interface seem to negate any improvements that might be in the latest version. So I'd be wary of this available update and treat the latest version as being still in beta.
The 6.10.3 inteface does keep coming up and saying that a later release (6.10.4) is available and do I want to install that. But after my experience with 6.10.5 I think I'll keep replying to ignore the optional update and stick with 6.10.3 that has been stable for a long while.
Chuck.
SebastianNielse
May 13, 2021Tutor
none.
I first tought it was SMB Plus, because it was the only app I had installed when the problem first appeared after updating to the beta.
Then I factory resetted the device, and reinstalled SMB Plus manually by uploading. Then it crashed again and got into a login loop.
I then tought it was the SMB Plus app that was the culprit... but it was just a RANDOM OCCURENCE... It just happened by random that the web interface broke just after installing the SMB Plus app.
Because when I factory resetted a third time, the web interface started looping on a freshly factory resetted device. The only thing I had done was gone through the setup wizard, no apps, no share config, nothing. After that, the device was TOTALLY untouched, but still it loops. It was like it was packed out of its cardboard box.
It seems just merely viewing something related to apps causing it to loop, like it gives up and tries to reset.
Since the start page contains a "Recommended apps" pane, I think its that pane timeouting, and causing it to reset.
Because when the web interface works (it randomly works) the "available apps" menu is totally blank.
May 13, 2021Guru - Experienced User
Interesting. I put the released 6.10.5 on my RN102 yesterday, and didn't see this behavior.
The Apps and Featured Apps sections display normally on the system tab, and both the Installed Apps and Available Apps pages on the Apps tab do also.
FWIW, SMB Plus is installed on the system.
Did you try connecting from an incognito/private browser window?
