ChuckMilne
May 08, 2021Initiate
Firmware 6.10.5 web interface broken in final release
My RN10200 had a 2tb drive die - so I replaced with two 4TB Seagate Iron Wolf NAS drives. There was a notice that a new version of the firmware was available 6.10.5 so I figured I should update this....
- May 09, 2021
I was eventually able to get Firefox on my laptop to get on the the NAS web interface after doing a lot of playing around clearing caches/histories, etc. So I chose the firmware update feature in the interface to go back to the 6.10.3 version. After a reboot this seem to allow access to the NAS interface from everywhere again. So I'm not sure what the advantages might be of 6.10.5 - but the problems with the web interface seem to negate any improvements that might be in the latest version. So I'd be wary of this available update and treat the latest version as being still in beta.
The 6.10.3 inteface does keep coming up and saying that a later release (6.10.4) is available and do I want to install that. But after my experience with 6.10.5 I think I'll keep replying to ignore the optional update and stick with 6.10.3 that has been stable for a long while.
Chuck.
hr_sokolow
Jul 21, 2021Aspirant
They have never done a properly functioning update yet. Every time you have to dance with a tambourine.
But your advice to click quickly on "Settings" and to select the "Beta" version helped!
You don't even need to go back to version 6.10.4. And that's how it works. At last!
MANY THANKS TO YOU FROM RUSSIA.
Hooray!
Jul 21, 2021Guru - Experienced User
The 6.10.5 hotfix solves this particular problem, so if your NAS can reach the internet you can safely update to 6.10.5.
