shybear
Dec 24, 2020Follower
Firmware ReadyNAS Duo RND2000 s/n2102917Y00C1B
hi I bought a ReadyNAS Duo RND2000. On label its written that its v2 and the actual firmware is RAIDiator 4.1.16. Looking on support pages for v2 all firmwares starts for 5.x.xx instead on v1 for 4...
rn_enthusiast
Dec 24, 2020Virtuoso
So, this is really confusing and has always been :)
There is a Duo_v1 (version 2) and a Duo_v2. You have a Duo_v1 (version 2). The label on back is highly confusing.
The Duo_v1 (version 2) has a charcoal black chassis where it says "ReadyNAS Duo" on the front:
https://www.netgear.com/support/product/RND2000v1_%28ReadyNAS_Duo_v1%29.aspx
The Duo_v2 is a metallic-grey chassis where it says "ReadyNAS Duo V2" on the front:
https://www.netgear.com/support/product/RND2000v2_%28ReadyNAS_Duo_v2%29.aspx
The latest firmware the for the Duo_v1 is 4.1.16.
You can upgrade RAM on these models. Some users here have had success with that. There are people on these forum that know more about that procedure than I, so I leave them to chime in on that part.
