XrayDoc88
Dec 16, 2017Apprentice
First Time Boot Question
I bought a diskless ReadyNAS 628X and added 48 TB of brand new hard drives. I just turned it on for the first time. The setup instructions said to wait for a steady blue "power led" and the IP to b...
- Dec 17, 2017
Thanks again for your feedback.
XrayDoc88
Dec 17, 2017Apprentice
Well, there was no blue power LED that ever magically appeared. I think this is just an example of the Netgear "Installation" pamphlet not being accurate for all ReadyNAS models. Besides the blue push buttons on the front of the unit, the only blue LEDs present are behind the door, next to the drive bays. It would be nice if the pamphlet could be updated to warn the user that you should expect the message "resyncing data", even on a brand new diskless unit. With 48 TB of new hard drives, my unit was "resyncing data" for approximately 16 hours!. It would also be nice if the manual didn't ask you to wait for a steady blue power LED that doesn't exit. :)
mdgm-ntgr
Dec 17, 2017NETGEAR Employee Retired
- mdgm-ntgrDec 18, 2017NETGEAR Employee Retired
The instructions say "Wait for the Power LED to turn solid blue or for the status display screen to display the system’s IP address."
On systems that don't have the Power LED you'd wait till the status display screen shows the I.P. address. This should be pretty quick. If the screen has gone blank again you can use the arrows to find the I.P. address.
