NormG1
Oct 02, 2021Follower
Fixed IP with unknown Subnet Mask - Cannot Log In
I have an very old ReadNAS Duo 1TB Raid. I was able to log-in to all the shares and the admin page. I was trying to get all the data off the NAS and FTP wasn't working. But I was on a differe...
Oct 02, 2021Guru - Experienced User
NormG1 wrote:
I changed the fixed IP from 192.168.0.56 to 10.0.0.99.
I think I may have used the wrong subnet mask. I think I entered 255.255.255.0.
Nothing wrong with using that subnet mask. What is the IP address range that your router is using?
NormG1 wrote:I was able to log-in to all the shares and the admin page. I was trying to get all the data off the NAS and FTP wasn't working.
If you were able to see all the shares, then changing the IP address from 192.168.0.x to 10.0.0.x was the wrong thing to do. Your FTP issues had a different cause.
NormG1 wrote:
In hindsight, I should have used DHCP.
So I manually set my MacBook to use 10.0.0.1 and I still cannot log into the Admin Page.
Connect the NAS ethernet cable directly to the MacBook, and set the MacBook to use 10.0.0.1. Then log in via https://10.0.0.99/admin.
I agree you should be using DHCP instead of static IP addresses. You can reserve an IP in the router if you want the NAS to have a persistent address.
