Matt_Eriksson
Jan 09, 2016Aspirant
Flashing new FW to RNDU2000
So, i bought a used Netgear Ultra 2 as a backup to my existing RNDU2000, how ever it won´t boot and is not discoverd by my router ( Asus RT-AC87U ) So i tried to flash it using the inofficial...
JennC
Jan 09, 2016NETGEAR Employee Retired
Hello Matt_Eriksson,
Welcome to the community!
Does the RAIDar see the NAS? What RAIDiator version did you flash it with?
Are the disks you are using with it empty and no partitions?
mdgm-ntgr
Also pressing and holding the power button would force shut the unit off. To do USB Boot Recovery you press and hold the backup button when powering on the system.
Did you follow the Unofficial Guide for USB Boot Recovery for x86 systems, running the .exe file included in the zip file to prepare the USB key?
Can the unit boot to the boot menu?
