carpe01
Mar 11, 2019Follower
Flex-raid/Raid Question
Hello, sorry if this is a duplicate question, I couldn't find an answer. I purchased a RN214, arriving later this week. I started with 2 WD Red 6TB drives. I'm looking to run RAID 1. I'm not usin...
Marc_V
Mar 12, 2019NETGEAR Employee Retired
Hi carpe01
Welcome to the Community!
X-RAID is an auto-expandable RAID technology that is available only on ReadyNAS systems. This is usually used by first time NAS users or users without extensive knowledge on RAID system.
X-RAID allows you to add storage space without reformatting your drives or moving your data to another location. Because the expansion happens online, you can continue to use your ReadyNAS system while the volume capacity increases. As Sandshark said, one limitation of X-RAID is that it's a one volume architecture and all disks that you will plan to add will be added to that volume and also there are advantages to that such as easy management and the auto expansion feature.
On the other hand
Flex-RAID/RAID allows you to have multiple volume setup on your system and choose what RAID leve you will be using. However, with Flex-RAID formatting, if you want to add disks to expand your storage capacity, you must back up the data to another system, add a disk, reformat the RAID volume, and restore the data to the new RAID volume. With X-RAID, none of those administrative tasks are required. Instead, with X-RAID, your volume automatically expands to accommodate additional disks or larger-capacity disks.
Hope this helps!
Regards
