Wired570
Aug 15, 2019Aspirant
Folder details
Hi everyone. I have the ReadyNas 102 and I'm wondering if there's a way to see folder details (size, files, etc) I have a few TBs on two drives but it seems I only have access to see the folder tree ...
- Aug 15, 2019
Welcome to the Community!
Are you checking it on the Admin page or on Windows explorer? If you want to see the folder details on the Admin page (Protocol used, consumed space, etc) then you can use the Share view
Changing it to Browse view will get you to the Folders and Files available
Under Windows explorer Just change the View mode
HTH
Regards
