tigerten
Aug 10, 2024Luminary
For those interested to install alternate OS
10-pin motherboard USB to regular USB flash drive adapter This is the adapter I bought and it works. Simply remove your daughter board and store it for backup. Plug this and extends to the ...
ReadyAS
Sep 04, 2024Guide
tigerten wrote:"[...]
I currently run the synology OS. It works well. I am sure you install any OS on it. "
On what readynas unit?
- tigertenSep 04, 2024Luminary
628X
- ReadyASSep 07, 2024Guide
Thank you for your answer tigerten. Could you give me any tip/link how to install the DSM and write me please, is it fully functional, supports all the 8 bays, 10TB network cards, etc.?
- tigertenSep 07, 2024Luminary
instruction is readily available by googling. It is the redpill ARC loader.
yes, it fully functional.
I did not test whether it works with full 8 bays as I do not have 8 disks. But all bays works and even the M.2 slot.
The 10G ports work on my 1GB network. I do not have the 10G infrastructure.
I would not touch the original daughterboard.
you will need a graphics card.
