MarkLOrbi's avatar
Sep 28, 2018
Alternative to IP passthrough
I have an AT&T uverse modem/router and the Orbi. Uverse continually has problems that I need to call AT&T about and the first thing I have to do is disconnect the Orbi or they blame all the problems on it. So I read an idea that I think might solve my problem, I'd like to connect a LAN port on the uverse router to a LAN port on my orbi router. The only thing I really care about using on the orbi is the wifi radio. This configuration would allow me to tell AT&T there's no other router connected, and allow the uverse router to continue to provide dhcp, nat and firewall services. The only thing the orbi will be providing is wifi radios. Is there any downside to doing this?
  • michaelkenward's avatar
    michaelkenward
    What you suggest is to use the Orbi router as a wifi access point.
    There is a manual for the Orbi WiFi System somewhere at the end of this link:
    >>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
    See the section Use the Router as a WiFi AccessPoint.
    Only if any of this stuff is important to you:
    Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
    • MarkLOrbi's avatar
      MarkLOrbi
      Guide
      Great, that's exactly what I wanted. The only thing I would have liked to hang onto was a visitor network, but it's not that important.
      • BBB73's avatar
        BBB73
        Apprentice
        You can still have a guest network in AP mode.
  • FURRYe38's avatar
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
  • FURRYe38's avatar
    You'll have to see if Guest Network is avialble in AP mode. I believe it required Router mode to work.
    Try suggestion #2...
