tigerten
Aug 10, 2024Luminary
For those interested to install alternate OS
10-pin motherboard USB to regular USB flash drive adapter This is the adapter I bought and it works. Simply remove your daughter board and store it for backup. Plug this and extends to the ...
tigerten
Sep 04, 2024Luminary
628X
ReadyAS
Sep 07, 2024Guide
Thank you for your answer tigerten. Could you give me any tip/link how to install the DSM and write me please, is it fully functional, supports all the 8 bays, 10TB network cards, etc.?
- tigertenSep 07, 2024Luminary
instruction is readily available by googling. It is the redpill ARC loader.
yes, it fully functional.
I did not test whether it works with full 8 bays as I do not have 8 disks. But all bays works and even the M.2 slot.
The 10G ports work on my 1GB network. I do not have the 10G infrastructure.
I would not touch the original daughterboard.
you will need a graphics card.
