Goodwinteam1
May 01, 2020Aspirant
forgot share password
Hi Guys Haven’t touched Nas in years, been working for family with no problem, lost connection to shared drives had to format Pc, Now can remember password to access drives Can access Nas but str...
May 01, 2020Guru - Experienced User
Can you tell us what firmware you are running?
Also, just to make sure I understand your previous post: You are able to log into the NAS admin web page?
- Goodwinteam1May 01, 2020Aspirant
Hi Yes
i can log into web page ,no problem , Am a complete novice with this
raidar 4.1.4
Thanks
- SandsharkMay 01, 2020Sensei
You can, of course, just use the admin credentials to access the shares. But if you prefer not to (and there are some reasons not to), you can use your admin access to the GUI to simply change the password for the user name you want to use to something you'll now remember. There are not separate passwords for different shares, per se. Access is by user. Each user has permissions to read or write to specific shares. If you are using a personal share, then only the user who owns it and admin have rights in it.
Hi ive tried to use my admin user name and password to get into shares but wont let me , also dont have any users , as it was just to be used as a family storage drive so all shares are disabled with no paqsswords
but still cant get in
thanks for the reply
- StephenBMay 01, 2020Guru - Experienced User
Goodwinteam1 wrote:
Hi Yes
raidar 4.1.4
Raidiator 4.1.4? Are you seeing that in web UI or are you looking at the label on the NAS?
That's extremely out-of-date - ~12 years old. Have you ever updated the firmware?
Have had it over 10 years as family storage , never had problem with it till now
this is the info from frontview
took my host name and serial off
Hostname: Model: ReadyNAS NV+ [X-RAID] Serial: Firmware: RAIDiator 4.1.16 [1.00a043] Memory: 256 MB [2.5-3-3-7] IPv4 address:: 192.168.0.17 Volume C: Offline, X-RAID, 4 disks, 100% of 2782 GB used
