D_Ace
Nov 25, 2021Aspirant
From scratch; 'resyncing' new drives is taking a week, should I be concerned? Follow Up
I wanted to follow up on the original article but it was closed (https://community.netgear.com/t5/New-ReadyNAS-Users-General/Connect-2-ReadyNAS-104-via-USB-for-data-transfer/m-p/2165074#M47178). I'v...
Sandshark
Nov 26, 2021Sensei
What specific drives are you using? I hope that "good deal" wasn't for "archive" drives or any that are SMR, as they are not a good choice and will have very poor write performance.
D_Ace
Nov 26, 2021Aspirant
yep..not SMR
First NAS - 4 x seagate 8TB st8000vn0022 Ironwolf's
Second NAS - 1 x HGST 8TB + 3 x Toshiba hdwr180 8TB (this was the crap shoot with the 3 toshiba drives under $200 cdn each plus my spare HGST)
So far so good...but again, second nas is going to be DAYS to resync
HTH
- SandsharkNov 26, 2021Sensei
While you havew access to the admin GUI, I suggest you download the log zip file and look for any reported SMART errors. I have seen reports of sync errors on Toshiba X300 series drives (though most are old, so the problem may be fixed), and those would definately slow down a sync.
Also be aware that the time estimate for a sync is often quite a bit off at the beginning.
- D_AceNov 26, 2021Aspirant
Thanks Sandshark!
Downloaded the logs but on first inspection, nothing seems to standout (no apparent SMART errors) but could be looking in wrong spot. In which log file would that error be displayed?
Thanks again for the follow ups...appreciated.
And for reference...approximately 22% through resync and just over a day passed...
- SandsharkNov 27, 2021Sensei
disk_info.log contains the SMART data. dmesg.log might also contain relevant information. I've not done a sync similar to yours on a 100 series machine. Given their limited processing power and the large number of calculations that go into a sync, I'm not sure your progress is that unusual.
