timharrisnl
Aug 06, 2017Aspirant
FTP transfer speed
hi, I recently bought a second hand Readynas duo (RND2000v2). Had some headaches so far getting it set up.. mainly because it's labled RND2000v2 on the sticker, whilst in reality it is not a v2 b...
- Aug 09, 2017
thanks JennC,
actually after some days of trouble shooting I have finally found a solution (as the issue was come and go)..
I have stopped using Filezilla for FTP and switched to now using FlashFXP.
Speeds are constant now, no more timeout's etc. happy :)
timharrisnl
and the weirdest thing..
without changing anything at all... an hour or two later it's now working at the same speed as other devices..
Don't know why, but happy :)
JennC
Aug 08, 2017NETGEAR Employee Retired
Hello timharrisnl,
Maybe it needed some time :)
This article might help you with connection speed for legacy units. I also suggest to always have full backup of important data.
Welcome to the community!
- timharrisnlAug 09, 2017Aspirant
thanks JennC,
- JennCAug 10, 2017NETGEAR Employee Retired
Hello timharrisnl,
Thanks for the update. I see, so it appears there is something with FileZilla that affects the speed. It could be something in the background running and affecting the performance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
