chirpa
Dec 23, 2007Luminary
FXP support (toggle of AllowForeignAddress in proftpd)
Would be nice to have this as a togglable option as to not need to enable SSH to modify it. Details: http://www.proftpd.org/docs/howto/FXP.html
ReadySECURE
Jun 19, 2012Apprentice
The best option for you when using SSH is to have a current backup of your data. Worst case scenario a factory default can be attempted. Netgear may deny the software support of the warranty if SSH is the direct cause of the issue, however the hardware warranty will still be supported.
