chirpa
Dec 23, 2007Luminary
FXP support (toggle of AllowForeignAddress in proftpd)
Would be nice to have this as a togglable option as to not need to enable SSH to modify it. Details: http://www.proftpd.org/docs/howto/FXP.html
Jun 20, 2014Guru - Experienced User
AllowForiegnAddress is already set to "on" in my system (running 4.1.13).
Mr_B wrote: It's been a few years... Still no easy solution for us SSH & Linux disadvantaged users?
Got a ReadyNAS NV+ V1 i'm about to clean out, FXP would be the fast & easy way, hence i poke this ancient thread.
B!
You can confirm this by downloading the configuration zip, and looking at etc\proftp.conf.
You can change it by using a windows editor that preserves linux newline conventions - notepad++ is a free one. Don't use notepad or wordpad. Once changed, update the zip, and restore the configuration.
Note this configuration only works if the ftp port is not 21.
