chirpa
Dec 23, 2007Luminary
FXP support (toggle of AllowForeignAddress in proftpd)
Would be nice to have this as a togglable option as to not need to enable SSH to modify it. Details: http://www.proftpd.org/docs/howto/FXP.html
Jun 20, 2014Guru - Experienced User
:roll:
Mr_B wrote: Cant seam to access etc\ so i assume thats one of those things you need SSH or "other means" for...
READ MY POST AGAIN. It gives instructions on how to see this from Windows, and how to change the conf file from Windows.
(a) download the configuration zip from frontview
(b) etc\proftpd.conf is in the zip file
(c) you can change it with notepad++ and put it back into the zip
(d) then upload the configuration zip from frontview.
What firmware are you running btw?
