chirpa
Dec 23, 2007Luminary
FXP support (toggle of AllowForeignAddress in proftpd)
Would be nice to have this as a togglable option as to not need to enable SSH to modify it. Details: http://www.proftpd.org/docs/howto/FXP.html
Mr_B
Jun 20, 2014Guide
Probably not. I just didn't really see any reason for bothering with it, my setup is near bog standard, with a LED mod and the transmission mod installed. If you say it's set to on, and should work, then it's set to on, and works. The issue is to be found on the other end, and it's, as it turns out, harder to get support for the R6200 router, then it is to get it for the ReadyNAS NV+.
StephenB wrote: Also, is there some reason why a Frontview FTP backup job won't do what you need?
You've been very helpful, i got all the answers i needed in a single line, the rest is perhaps useful some other day, but at this point i don't really see any reason to try and figure out what to do and where to do it. At this point it seams likely your referring to some backup feature in Frontview that generates a zip, i was looking at the file areas, and found jack all. Anyway, the answer has been given, i went onwards from there, and got the dreaded "no help to be had here" message from NetGears live chat support, which means i'm simply pulling the USB storage of the R6200, and hooking it to the HPX310 instead, and ignore the R6200 from here on out. It's not worth the headache.
B!
