DC423
Jun 01, 2020Aspirant
getting files and folders off rn102 3TB
Hi I just managed to get my Radynas 102 to be seen by ready cloud on my laptop.I would like to copy all the files and folders to an external drive, as this sytem is a bit glitchy for me .So it would ...
DC423
Jun 02, 2020Aspirant
Hi, thanks for replying, I currently am unable to access the admin page, during my recent firmware update and the Netgear incistance on marrying my old readynas login/password to the My netgear account has left me locked out, (no passwords work including the original admin/password ) I even have gotten the password reset not available screen.
I currently do have the ready nas open and can see the files / folders. I can download to laptop then move to external drive but i would like to skip that step and just offload / download directly to external drive.it a couple of TB's and dont want to baby sit them. My laptop does not have enough onboard storage available to make this easy.
How do i use the ip of the nas in file explorer, have never tried that.
Thanks
DC
Jun 02, 2020Guru - Experienced User
Something wrong here, as the NAS admin account wouldn't have been affected. Are you logging in directly to the NAS web ui
( https://nas-ip-address/admin )?
An OS-reinstall from the front panel would change the admin password back to password. See pages 20-22 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
Enter \\nas-ip-address into the file explorer address bar. Make sure you use the correct slash. Note it might prompt you for a NAS account/password.
- DC423Jun 02, 2020Aspirant
Hey there, I am currently logged into the readycloud.netgear.com site. this is where i see my drive, files and folders. when i go to manage page and select the admin page link from the left column next to the main nas drive, thats where it asks me for login info. and i have tried to use the login "admin" and password " password". as well as my old readynas login and my new my Netgear account login with o luck. I do not remember how to login directly to the ip.
thats where i am at for now.
Thanks
DC
- StephenBJun 03, 2020Guru - Experienced User
Note you don't need readycloud if you are on the same network as the NAS.
Do you get the login prompt when you connect direct to the NAS IP address (https://nas-ip-address/admin )
Can you access the shares via file explorer?
The change to single-sign-on in readycloud doesn't affect your NAS admin password. Do you remember that password? Normally you would have changed it to something other than password.
- DC423Jun 03, 2020Aspirant
Hi, finally got to admin Page!!!! (had to find passowrd notes and try a few combos,- I had moved and changed laptops) so now i am in , forgotten how to use system. if i want to copy all files to an external usb hard drive is that possible in a single activity
Thanks
DC
