MikeTexas
Aug 21, 2023Follower
Getting New NAS question
I currently has a ReadyNAS 524X with 4 8TB drives, one serving as a parity check drive. I am looking into an 8 bay ReadyNAS RN626X/RX628X. I have three questions about the process and I hope some...
Aug 22, 2023Guru - Experienced User
MikeTexas wrote:
1) can you mix HDD sizes, say 4 8TB HDDs with 4 4TB HDDs and still keep the parity check feature;
The volume is expandable, in general you can't add in smaller drives to the existing array.
You could switch to FlexRAID, and create as second 4x4 TB RAID-5 volume. That would have have the space of your current volume (12 TB or ~10.9 TiB). Yhen you can shift some of your shares to the second volume.
MikeTexas wrote:
2) can drives just be moved from the current 4 Bay NAS to a newer 8 bayNAS without having to reinstall everything, i.e., just move the drives and keep the data as is and
Yes.
MikeTexas wrote:
3) I have a space issue so can the new RN626X/RX628X NAS be laid on its side permanently with no concerns of drive crashing or damage.
Not something I've ever needed to do. It should be ok, as long as you don't block the airflow.
- Jan 17, 2024Retired_Member
