jjcf89_2
Mar 23, 2019Tutor
gmail auth not working after trying to relogin
Read the other forum posts after getting the email from gmail. And attempted to sign out and log back in. But now I can't authenticate.
* Clicked sign out
* Clicked Singed in With Google
* Authenticated in gmail popup
* Email form fills in with information and spinning progress bar shows up
* After spinner disappears, the email form is empty and Send Message doesn't work. Gmail button says "Signed in with Google" however.
On my system all those blank fields (user, password, smtp server, etc) are filled in.
Stephen,
Does the form on your RN show
[Clear] and [Send Message]
or
[Sign Out] and [Send Message]
We had (granted, 6.10-RC2) a manual configuration in place before, with a manually configured advanced settings. Used the [Clear], ... run over the Gmail process for acquiring the token, not it shows [Sign Out] below, sending a [Send Message] Email works as expected. The odd part - and that's why I'm writing - is that the manual config from before wasn't cleared by [Clear] - much more it appears the information is somehow retained in the background. In my opinion, the from should not remain filled and filed.
