MrBlond's avatar
MrBlond
Groups in Transmission
Hi,
I just recently bought a readynas 102 and almost have it configured. I am using sickbeard TBP and Couchpotato to find the movie and tv torrents which transmission downloads. I used to do this with SABDNZB and there you can create cagetories / groups based on the source of the nzb. From sickbeard they would be categorised as TV, Movies from couchpotato etc. SAB would download the categories in different folders. for postprocessing. In transmission this is not possible, you can only set the download folder and that's it. Both couchpotato and sickbeard are monitoring that folder for finished downloads. Sometimes they mix it up and movies get processed as tv shows and vice versa. I would like to have group support to this version of transmission. I read it already exists on the mac. Or perhaps you solved this issue in another way? If so i would like to hear about it!
ProSupport for Business
