dnew24
Apr 08, 2016Aspirant
Hard Drive Upgrade
Upgraded the factory installed 2TB drives with 6TB WD60EFRX drives. I installed one at a time and waited for the volume to rebuild each time. The nas recognizes the drives but the volume is still t...
JennC
Apr 08, 2016NETGEAR Employee Retired
Hello dnew24,
Please provide the model number and FW version of the NAS.
Welcome to the community!
dnew24
This is a ReadyNAS 316 - 6 bay with firmware 6.4.2 installed.
- JennCApr 08, 2016NETGEAR Employee Retired
Hello dnew24,
RAID 10 is FlexRAID and it is not expandable. You need to back the data first while you still can then factory reset the NAS with the new disks.
This link might help.
- dnew24Apr 08, 2016Aspirant
Thank you. That was my fear.
- mdgm-ntgrApr 10, 2016NETGEAR Employee Retired
In 6.5.0 expansion of RAID-10 volumes should work. If you have not already done the factory reset you may wish to try ReadyNASOS 6.5.0-T338 (Beta 2)
