Bhushan's avatar
Bhushan
Having RN212 and need to upgrade the Drives to 10TB
Dear Community,
I would request you to please let me know if the available Model No. ST10000NM017B for Seagate 10TB  will be compatible with ReadyNAS 212 as the below list doesn't show the model no.
https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List
Please help me. Thank you in Advance.
    • Bhushan's avatar
      Bhushan
      Hi Stephen,
      Thank you very much for your quick reply and update.
    • StephenB's avatar
      StephenB wrote: so the current Ironwolf model you are thinking about is a good choice.
      I should have said Exos of course.
      FWIW, I have 14 TB Exos ( ST14000NM001G) in an RN202 for quite a while, and have had no issues with it.
ProSupport for Business
