br31m0nd0
Apr 09, 2025Aspirant
Help ReadyNAS 202 admin access and data migration
I've recently unearthed my ten year old ReadyNAS 202, including two 3TB HDDs, from my loft space. The device looks to be fully functional, it is recognised by my laptop when connected via ethernet c...
br31m0nd0
Apr 10, 2025Aspirant
Thank you very much Sandshark, the OS reinstall did the trick. I'm now able to access the admin page and have access to all of my media files. đ
Does anyone have a recommended approach for data transfer to another NAS or storgage device?
Apr 10, 2025Guru - Experienced User
It depends on the destination device.
If you are transfering to a disk connected to a PC, then there are several free programs you can use for block transfers. FreeFileSync is one. You can also schedule backups with most of these programs.
If you are transferring to another NAS, then you can use either the backup jobs in the ReadyNAS, or use a similar facility in the other NAS. Use rsync as the protocol if you can.
- SandsharkApr 10, 2025Sensei
Backup jobs are also great for transferring to a USB drive connected directly to the NAS -- much faster than to a drive attached to a PC. If you use an NTFS formatted drive, then you can read it with your PC.
