nickel22222
Jan 01, 2019Tutor
Help troubleshooting rndp6000
I am troubleshooting some issues with new old (newly acquired) RNDP 6000 100NAS.
This board won't allow me to post my log in zip format.
Not sure if disk network or other problem. Trouble...
- Jan 04, 2019
nickel22222 wrote:
The wifi uses your Netgear DC112A-100NAS cradle with ATT wifi hotspot.
Uses "ac" I think.
It's not mine - I don't work for Netgear (neither does anyone else you've been connecting with here). This is a community forum, you are talking with other users.
It is an 802.11ac device (2x2 in the 5 ghz band), so you should be seeing better speeds if you are close to the cradle. Perhaps confirm that you are connecting to the 5Ghz band.
nickel22222
Jan 04, 2019Tutor
Uses "ac" I think.
Coincidentally LAN connections to this cradle bought on 1-12-18 are erratic at times.
Jan 04, 2019Guru - Experienced User
Uses "ac" I think.
