EndersShadow
Dec 30, 2021Aspirant
Help upgrading ReadyNas Ultra 2 Plus memory
I have a ReadyNas Ultra 2 Plus that I am looking to do a few things on. Replace the external powersupply (it crapped out on me on the same day I upgraded the HDD's :smileymad: Upgrade from Raidar ...
EndersShadow
Jan 02, 2022Aspirant
Thanks! I ended up going with a InstallerCCTV 12V 5 Amp UL Listed AC DC 60W 2.1mmx5.5mm powersupply and a stick of Crucial 2GB Single DDR3/DDR3L 1600 MT/S (PC3-12800) memory. I'm aware the memory will operate at the PC 8500 speed, but otherwise I think it should work without causing any issues, and let me upgrade it when I get it in in two weeks (after the unit is operational).
Sandshark
Jan 02, 2022Sensei
I've used PC3-12800 memory in an Ultra/Pro 2 with no issue. It's actually a lot easier to find used than the slower stuff. Getting a supp[ly rated for CCTV was a good move. They tend to have better regulation, especially at inrush, than those just listed as for LED lighting.
- EndersShadowJan 09, 2022AspirantShould I upgrade the BIOS with the new hard drives in pace or without?
I’m basically starting from square one and have already dropped in the new memory, the PSU came today and the new hard drives have no data on them, so they will need to be setup….- StephenBJan 10, 2022Guru - Experienced User
EndersShadow wrote:
Should I upgrade the BIOS with the new hard drives in pace or without?With. Though you can do it with only one drive installed - avoiding the resync.
- EndersShadowJan 10, 2022Aspirant
Thanks everyone, with your help I have:
- Upgraded the Memory from stock 1 gig DDR3 to 2GB DDR3/DDR3L PC3-12800
- Updated the BIOS/ moved to ReadyNAS OS6
- Added 2 4TB 5400 RPM CMR WD Red drives
- Purchased a new powersupply
The device is up and running and I'm currently restoring settings and then will transfer the data from my HTPC back to the NAS
