sylvainp
Jan 21, 2019Aspirant
ReadyNAS Pro Business Edition (Memory upgrade)
Hi all, I recently start playing around this weekend with my ReadyNAS Pro business Edition and I have update the BIOS to Flame V2.0.
Also update to OS 6 and what a difference !
Also bought on Ebay a Intel Core 2 Duo E7600 CPU. Waiting for it.
Now I want to upgrade the Memory from 1GB to 4GB
What memory module is compatible with the latest BIOS and the CPU (E7600) and motherboard.
What brand, model, speed, CAS latency
Thank you !
Hi sylvainp
I think this thread might just answer your query https://community.netgear.com/t5/New-ReadyNAS-Users-General/Memory-upgrade-for-ReadyNAS-Pro-6/td-p/1072715
You may want to check this too.
Hope this helps!
Regards
- Marc_VNETGEAR Employee Retired
Hi sylvainp
Hope this helps!
Regards
- sylvainpAspirant
Thanks for the link. As I can read most people use memory with FSB 800 Mhz. The CPU I will use is a Core 2 E7600 with a FSB of 1066 mhz.
Does the motherboard compatible with memory with a FSB of 1066 Mhz ?
This way it will match the FSB of the CPU at 1066 Mhz.
Thank
- sylvainpAspirant
I forgot to ask what memory voltage we need or compatible ? 1.8v ?
Will G.SKILL 4GB 2X2GB DDR2 1066 PC2-8500 F2-8500CL5D-4G
BPK with voltage from 2.0 to 2.1v work ?
