Denis1's avatar
Denis1
Tutor
Dec 28, 2017
Upgrading CPU for my ReadyNAS Pro Business Edition
I upgraded my ReadyNAS Pro Business Edition today, only upgraded the CPU with Xeon X3230 Quad Core CPU SLACS 2.66GHz 1066MHz.
Reboot and everything stated normally, the fans run as fast as possible. Nonaml. I checked the fan speeds and I see no speed for CPU and Sys.
And then there alerts. Did the power supply going, bad CPU or something else
DDB18 power is out of normal range [expected: 1.80 current: -0.00].
AVCC power is out of normal range [expected: 3.30 current: -0.00].
VCC3 power is out of normal range [expected: 3.30 current: -0.00].
VCC1_25 power is out of normal range [expected: 1.25 current: -0.00].
VCC1_5 power is out of normal range [expected: 1.50 current: -0.00].
VCC1_05 power is out of normal range [expected: 1.04 current: -0.00].
3VDUAL power is out of normal range [expected: 3.30 current: -0.00].
VBAT power is out of normal range [expected: 3.30 current: -0.00].
Fan 1 has failed (SYS -1 rpm).
  • Denis1's avatar
    Denis1
    Jan 02, 2018
    That would be his prerogative. i'm sworn to secrecy, but I'm sure he's done it in the past and will do it if it comes up again.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    I see from the screenshot that you're running 4.2.31
    If you download the logs what is the date in bios_ver.log?
    • Denis1's avatar
      Denis1
      Tutor
      I upgraded to the bios 2
      07/26/2010 FLAME6-MB V2.0
      • Sandshark's avatar
        Sandshark
        Sensei
        It sounds like your NAS decided it needed a new configuration file because of the new CPU, and that didn't go well.  I'm afraid I don't know where the OS 4.2.x equivalent of /etc/systemd/system.conf is (unless maybe it's the same), but that's what controls the reported monitors in OS6.x and I assume there is one for 4.2.x as well.
        I hope you realize that that that processor has a higher TDP than the original and you may end up with cooling problems.  Unless you have some extensive parallel processing (like multiple PLEX streams), you likely could do as well with a Core2 Duo E7500.
ProSupport for Business
