sylvainp
Jan 21, 2019Aspirant
ReadyNAS Pro Business Edition (Memory upgrade)
Hi all, I recently start playing around this weekend with my ReadyNAS Pro business Edition and I have update the BIOS to Flame V2.0.
Also update to OS 6 and what a difference !
Also bought on Ebay a I...
- Jan 22, 2019
Hi sylvainp
I think this thread might just answer your query https://community.netgear.com/t5/New-ReadyNAS-Users-General/Memory-upgrade-for-ReadyNAS-Pro-6/td-p/1072715
You may want to check this too.
Hope this helps!
Regards
Marc_V
Jan 22, 2019NETGEAR Employee Retired
Hi sylvainp
Hope this helps!
Regards
- sylvainpJan 22, 2019Aspirant
Thanks for the link. As I can read most people use memory with FSB 800 Mhz. The CPU I will use is a Core 2 E7600 with a FSB of 1066 mhz.
Does the motherboard compatible with memory with a FSB of 1066 Mhz ?
This way it will match the FSB of the CPU at 1066 Mhz.
Thank
