EndersShadow
Dec 30, 2021Aspirant
Help upgrading ReadyNas Ultra 2 Plus memory
I have a ReadyNas Ultra 2 Plus that I am looking to do a few things on. Replace the external powersupply (it crapped out on me on the same day I upgraded the HDD's :smileymad: Upgrade from Raidar ...
EndersShadow
Jan 09, 2022Aspirant
Should I upgrade the BIOS with the new hard drives in pace or without?
I’m basically starting from square one and have already dropped in the new memory, the PSU came today and the new hard drives have no data on them, so they will need to be setup….
Jan 10, 2022Guru - Experienced User
With. Though you can do it with only one drive installed - avoiding the resync.
- EndersShadowJan 10, 2022Aspirant
Thanks everyone, with your help I have:
- Upgraded the Memory from stock 1 gig DDR3 to 2GB DDR3/DDR3L PC3-12800
- Updated the BIOS/ moved to ReadyNAS OS6
- Added 2 4TB 5400 RPM CMR WD Red drives
- Purchased a new powersupply
The device is up and running and I'm currently restoring settings and then will transfer the data from my HTPC back to the NAS
