EndersShadow
Dec 29, 2021Aspirant
Help upgrading ReadyNas Ultra 2 Plus memory
I have a ReadyNas Ultra 2 Plus that I am looking to do a few things on. Replace the external powersupply (it crapped out on me on the same day I upgraded the HDD's :smileymad: Upgrade from Raidar ...
Jan 09, 2022Guru - Experienced User
EndersShadow wrote:
Should I upgrade the BIOS with the new hard drives in pace or without?
With. Though you can do it with only one drive installed - avoiding the resync.
EndersShadow
Jan 09, 2022Aspirant
Thanks everyone, with your help I have:
- Upgraded the Memory from stock 1 gig DDR3 to 2GB DDR3/DDR3L PC3-12800
- Updated the BIOS/ moved to ReadyNAS OS6
- Added 2 4TB 5400 RPM CMR WD Red drives
- Purchased a new powersupply
The device is up and running and I'm currently restoring settings and then will transfer the data from my HTPC back to the NAS
