tigerten
Feb 17, 2023Luminary
here is how I created a local repository easily
Since the online repo expired a while ago, installation of previously installable packages are no longer installable, e.g. docker and portainer. Here is how I did by crating a local repo on a USB fla...
Sandshark
Apr 02, 2023Sensei
Thanks for that, but how did you install a version of xorriso that's compatible? I get this error message:
--- Help text of xorriso program xorriso lacks word "replay".
--- It will fail when trying to make the new ISO bootable.
Consider to get and compile GNU xorriso from
https://www.gnu.org/software/xorriso
and to export variable XORRISO with the binary's path.
I don't care if it's bootable or not, so I guess I could look at the script and see if that can be disabled. Or did you find a way to do that rather than install a more up to date xorriso?
tigerten
Apr 03, 2023Luminary
I used a debian 11 installation. I have no issues. Don’t how to help.
Sorry
Sorry
- SandsharkApr 03, 2023Sensei
I got to the point I figured out you must have. I removed the check for the option and it's use, then ran into the next roadblock:
mount: unknown filesystem type 'iso9660'I never tried to mount the CD's on the NAS, I mounted them in Windows and copied the files to the NAS. I'm going to do that again and put the files in their respective "mount" directories, remove the mount and unmount operations from the script, and see if that works. If it doesn't, then I'll just use those three directories as my repository.
- tigertenApr 03, 2023LuminaryPlayed with it. Same error as yours
If there is a place, i can upload it. It is big.- SandsharkApr 03, 2023Sensei
I thought I got around all the errors. But the iso it created is unusable because it changed all the file and folder names to upper case and limited their length. The available version of xorriso is just too old. I have a Debian VM I can use to create it if I really need to, but I just put the contents of the three BD .iso's into three directories and pointed to them.
It would take forever to upload to my OwnCloud. My download speed is very restricted.
