DaveBisping
Mar 01, 2017Aspirant
High CPU After updating to 6.6.1
I have just updated to production 6.6.1 from 6.6.1-T207, All appeared to go fine, but after about an hour I noticed that there appeated to be quite heavy disk usage, monitoring the NAS using TOP show...
- Mar 01, 2017
So something's wrong with plex. Are you using it?
If not, maybe just try uninstalling it.
Otherwise you might try downloading the current version from plex.tv and upload it on the web ui's app page. That might help. Some users have found they needed to use firefox to get the app install to work.
mdgm-ntgr
Mar 01, 2017NETGEAR Employee Retired
Do you have the anti-virus service enabled?
