DaveBisping
Mar 01, 2017Aspirant
High CPU After updating to 6.6.1
I have just updated to production 6.6.1 from 6.6.1-T207, All appeared to go fine, but after about an hour I noticed that there appeated to be quite heavy disk usage, monitoring the NAS using TOP show...
- Mar 01, 2017
So something's wrong with plex. Are you using it?
If not, maybe just try uninstalling it.
Otherwise you might try downloading the current version from plex.tv and upload it on the web ui's app page. That might help. Some users have found they needed to use firefox to get the app install to work.
DaveBisping
No Antivirus is disabled
DaveBisping
Watching Top there seems to be a pattern to it, the CPU is quite spikey, what I see is
CPU Quiet
copy kicks in takes upto 100% cpu for about 7 secs
apt-get kicks in fakes up 100% cpu again for about 7secs
CPU Usage returns to normal for about 5 secs
Then the process repeats, it's pretty much 100% consinstant
- StephenBMar 01, 2017Guru - Experienced User
Entering journalctl | grep -i "apt-" might give you some clues. Or maybe download the log zip and look in apt-history.log
- DaveBispingMar 01, 2017Aspirant
Thanks that has seem to have thrown up some more info, I see loads of entries of the form
Mar 01 14:27:14 DB-NAS sh[16401]: E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).Am I safe to do what is suugested??
The next step is to figure out what is doing the apt-get. Did you look at apt-history.log (you'll need to download the log zip to do that)?
