DaveBisping
Mar 01, 2017Aspirant
High CPU After updating to 6.6.1
I have just updated to production 6.6.1 from 6.6.1-T207, All appeared to go fine, but after about an hour I noticed that there appeated to be quite heavy disk usage, monitoring the NAS using TOP show...
- Mar 01, 2017
So something's wrong with plex. Are you using it?
If not, maybe just try uninstalling it.
Otherwise you might try downloading the current version from plex.tv and upload it on the web ui's app page. That might help. Some users have found they needed to use firefox to get the app install to work.
DaveBisping
I looked in Apt-history.log and that contains no entries later than 24th Feb
However looking in system,d-journal.log Shows a consitant set of entries of the following (some text rermoved
Q
Mar 01 14:42:16 DB-NAS systemd[1]: Starting Plex Media Server...
Mar 01 14:42:16 DB-NAS sh[19587]: dpkg-query: error: parsing file '/var/lib/dpkg/status' near line 8696 package 'readynasos':
Mar 01 14:42:16 DB-NAS sh[19587]: multiple non-coinstallable package instances present; most probably due to an upgrade from an unofficial dpkg
Mar 01 14:42:16 DB-NAS sh[19587]: No status data could be sent: $NOTIFY_SOCKET was not set
Packages
Mar 01 14:42:17 DB-NAS sh[19587]: Hit http://mirrors.kernel.org jessie Release.gpg
Mar 01 14:42:23 DB-NAS apache_access[2964]: Suppressed 1 duplicate messages
Mar 01 14:42:23 DB-NAS apache_access[2964]: 192.168.1.40 "POST /dbbroker HTTP/1.1" 200
Mar 01 14:42:30 DB-NAS apache_access[2964]: fe80::d5df:f26f:8235:e6d2 "POST /dbbroker HTTP/1.1" 200
Mar 01 14:42:32 DB-NAS sh[19587]: Reading package lists...
Mar 01 14:42:33 DB-NAS sh[19587]: Building dependency tree...
Mar 01 14:42:33 DB-NAS sh[19587]: Reading state information...
Mar 01 14:42:33 DB-NAS sh[19587]: libc6:armhf is already the newest version.
Mar 01 14:42:33 DB-NAS sh[19587]: You might want to run 'apt-get -f install' to correct these:
Mar 01 14:42:33 DB-NAS sh[19587]: The following packages have unmet dependencies:
Mar 01 14:42:33 DB-NAS sh[19587]: libgd3 : Depends: libvpx1 (>= 1.0.0) but it is not going to be installed
Mar 01 14:42:33 DB-NAS sh[19587]: php5-gd : Depends: libvpx1 (>= 1.0.0) but it is not going to be installed
Mar 01 14:42:33 DB-NAS sh[19587]: E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Mar 01 14:42:33 DB-NAS systemd[1]: fvapp-plexmediaserver-annapurna.service: Control process exited, code=exited status=100
Mar 01 14:42:33 DB-NAS systemd[1]: Failed to start Plex Media Server.
Mar 01 14:42:33 DB-NAS systemd[1]: fvapp-plexmediaserver-annapurna.service: Unit entered failed state.
Mar 01 14:42:33 DB-NAS systemd[1]: fvapp-plexmediaserver-annapurna.service: Failed with result 'exit-code'.
Mar 01 14:42:37 DB-NAS dbus[2156]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper)
Mar 01 14:42:37 DB-NAS dbus[2156]: [system] Successfully activated service 'org.opensuse.Snapper'
Mar 01 14:42:38 DB-NAS readynasd[2419]: Error: Connection failure: Connection refused
Mar 01 14:42:38 DB-NAS systemd[1]: fvapp-plexmediaserver-annapurna.service: Service hold-off time over, scheduling restart.
Mar 01 14:42:38 DB-NAS systemd[1]: Stopped Plex Media Server.
UQ
Mar 01, 2017Guru - Experienced User
