Mook1
Aug 02, 2012Guide
Hitachi 7K3000 HDS723020BLA642 - NV+ & Ultra 6 Issues
I'm trying to replace 2 hard drives on 2 different boxes. One is an NV+ which has 3 1TB drives the other is an Ultra 6 which has 3 other 2 TB drives. I'm replacing some drives that are getting erro...
Mook1
Aug 02, 2012Guide
"Then hot pull the drive in question, attach it to a Windows PC and use drive management to remove all partitions from the drive. Then hot re-insert the drive. The system should verify the drive and then start the resysnc."
I did this. I Frontview/Health tells me the disk is "dead". The log says, "Data volume will be rebuilt with disk 2."
The display on the Ultra 6 under the IP address says, "C: Unprotected".
Not sure what that means. Is there something I missed?
Note: When I inserted the disk the Ultra said, "Testing Disk", "C Unprotected" and finally "Disk Passed" then back to the "C: Unprotected" which seems to be permanent.
