Mook1
Aug 02, 2012Guide
Hitachi 7K3000 HDS723020BLA642 - NV+ & Ultra 6 Issues
I'm trying to replace 2 hard drives on 2 different boxes. One is an NV+ which has 3 1TB drives the other is an Ultra 6 which has 3 other 2 TB drives. I'm replacing some drives that are getting erro...
Aug 07, 2012Guru - Experienced User
Did you check the disk smart stats, or run vendor diagnostics? BTW, it is useful to look directly at the smart stats, since the vendor diagnostics generally pass marginal drives. Their failure threshold is definitely harder to reach than mine.
Mook wrote: Hi mdgm, I did hook them up to an old XP tower I have and they worked just fine.
